SimonB
Fuel Smell in the boot (trunk)
Post by SimonB »
I've begun to notice a fuel smell in the boot of my '84 GTV6. Last time I had this it was because the fuel tank was rusted out but this one seems ok. Its worse after its been left standing a while. I've checked the hose clips on the filler neck and the overflow seems ok. Is there anything else obvious I should check?
Seb
Post by Seb »
It is probably the rubber hose that connects the body with the tank. Mine got a crack in it and started leaking. It has been exposed to gasoline for 21 years now, so have a look att it.
Seb
156 V6 24v -98
GTV6 3.0QV-83
SimonB
Post by SimonB »
Do you mean the big thick one that goes to the filler neck?
Seb
Post by Seb »
Yupp! Thats the one!
Seb
156 V6 24v -98
GTV6 3.0QV-83
