plug wires
Posted: Wed Mar 12, 2008 9:12 pm
by sh0rtlife
ive got a few sets of "stock" wires here and wondering..can i pull the ends off of the stock units and replace the wire itself with some "new" solid core?..or am i looking at buying a full new set of wires.
since i can get some solid core with just dist ends for about 30$
Posted: Thu Mar 13, 2008 1:12 am
by Murray
sh0rtlife the problem which you'll have with this is that the the end of the stock wires have crimped-on terminals which thread into the resistor tubes.These terminals may be available from Bosch? but you will also need the correct crimping tool to install them on your new wires.
Posted: Thu Mar 13, 2008 3:08 am
by sh0rtlife
ive got a crimping tool for doing plug wires(unless these require a special one?)since ive made plug wires for my cuda's all sorts of sets for friends cars since around 93...so im no stranger to making plug wires....just never did a set of solid core yet or "hemi" style
my main concern was if i need some kind of special solid core or if the plug ends could be re-used....good chance i can re-use the crimped piece too as over the years ive gotten good at carefully prying "normal ones open to re-use on "odd" applications or quick roadside fixes...headers love to eat plug wires especially on A-body cudas(67-69)....bad header shape
guess i will take one of my "dead" sets apart for a better look...up to this point ive been swapping out bad ones for good one's on a single plug wire not a set...to avoid buying/making a new set..........and ive yet to see a "new" set that didnt stick out like a polished turd
Posted: Fri Mar 14, 2008 1:37 am
by Murray
sh0rtlife
Unfortunately I don't think this is possible.As you will see in my little diagram the threaded end tube of the terminal is crimped to the conductor and I found it impossible to undo that crimp without destroying the tube.Hopefully you'll prove me wrong.
