Ignition advance/retard 83 Euro
Posted: Fri Mar 25, 2011 11:18 am
I have an 83 euro, but late with the 84 onward running gear. so teh later timing marks.
@900rpm idel when I pull off the vacuum advance line, nothing happens at all, timing remains the same on the "F". The vacuum is working since the timing advances to "M" and beyond from about 1500rpm. is this normal for idle or is the vaccum device lazy?
