Wipers: no high speed
Posted: Mon May 02, 2005 10:07 am
by x-rad
85 GTV6...intermittent and slow speeds work fine. No high speed wiping, just stays at same slow speed with switch in high or low position. Any ideas?? Thanks.
Posted: Wed May 04, 2005 5:29 pm
by Burger
Itz probably your combination switch for the wipers.Every Italian car I've owned has had that problem.
Posted: Wed May 04, 2005 7:42 pm
by x-rad
Thanks, I will check the switch. The door lock came together just fine, thanks for the parts!! Maybe I will need a combi swith from you soon.....
