Hi, i`m on the look-out for the ignition control relay that sits above the fuse box, has 2 block connectors to it, one with 6 the other with 4 wires.......The car is a 1984 US spec and is different to the UK models....Maybe the same as EURO spec.? The car is now in the UK....
The car doesn`t have the relay at all.......so i`m stuck to get it running.....UNLESS someone has the wiring diagram so i can rig up another set of relays to do the same job...
I `m sure the 4 wire is live Batt+ , which then energises the 6 wire once the ignition is turned to ON , as that side is wired to feed the coil and distributor module.........
HOPE YOU CAN HELP.........Regds..
