persalls
Strange instrumentlight/indicator problems??
Post by persalls »
Hi guys!
The spring is just around the corner so I went out to finish some work that was left "half way trough" in the late autumn. The dash was removed due to fan end heater problems and everything except for the speed-cluster-lights(just the speedo) works just fine. A strange thing is that if I turn the lights on to check, the indication-light for the indicators in the bottom of the speedo will not work. When lights are out it does??? All other lights do work and the grounds behind the dash was refurbished, the only little thing I can´t find a place for is a orange cable behind the speedo that comes along with the cabling for the cluster. It has a flat connector( don´t know what it´s called) but there seems to be nowhere to connect it????
Any suggestions will be greatly appreciated since this might well be a MOT-problem.
//Brg, Per from Sweden
