Wicked Cool radiator
I am planning to upgrade to a Wicked cool radiator. http://www.cmwraceparts.com/New_Folder/New1.html
I am thinking of using a 24"x19" or 26"x19" (AC is currently removed).
This radiator is 3in thick.
There was a thread on the other site discussing this, but not much was concluded other than the correct dimensions.
I am just wondering what the people here think of this plan?
Stock things on these cars tend not to suck. Too bad I am an economic joke right now... Plus, the Wicked Cool radiator should be lighter due to its aluminum construction. The extreme front of the car is a good place to save some weight.
My car with the cooling problem is out of commission anyway. I plan use it for developing my engine project. That way I will be able to fun my new 3l gold while I am piecing together my engine project over countless months. I will be able to test fit everything on the car that is parked (plumbing and SC mounting). Then I will pull the motor for rebouilding. When it is finished, I will swap it into the Gold.
Hmm, my new Gold has a 2.5l radiator. Damn, that thing might not be up to the task of cooling the 3l in the Mexican desert...
Do you have heat problems right now or is it just "just in case"? A huge radiator is a good way to add weight. You do fill it with water/stuff you know.
Installed
Hi Everyone,
I know this thread has been dormant for awhile, but I just ran across it and we installed a Wicked Cool in our race car last week. It wasn't exactly plug and play, but once we got started, it went pretty smoothly. The radiator is designed for a Chevrolet, so the outlets are close to the correct spots. The big issue was locating the radiator vertically in the car and after brainstorming in Lowe's, we ended up using 2x4 brackets with high density foam. We bent the brackets to the height we needed and then used the foam to get a nice compressed fit in the bottom channel of the radiator with said brackets. We put a couple of holes into the crossmember to secure the brackets and trimmed the "flaps" on either side to expose all of the core. On top we were able to reuse the stock rubber block and it fits nice and snug with very little wiggle. Still left to do is mount a fan, but we will be using a low-profile Spahl unit. Hopefully we won't have any more on-track cooling issues. Here are some pictures.
1. Finished bracket with foam
2. Bottom of radiator with foam placed in channel
3. Installed
-damen
3. Installed
-damen
Rice University Society of Automotive Engineers
www.RacingOwls.com
www.RacingOwls.com
