Page 1 of 2
Radiator Fans GTV6?
Posted: Tue Nov 08, 2005 12:47 am
by Seb
Hey guys!
My fans are stuck after many years of standing still in dust and moist air, so i need new ones. I´ve tried to find used ones, but no answers. Brand new ones are more expensive than drugs!
Does anyone know another car/modell using the same fans?
Cheers / Seb
Cooling
Posted: Tue Nov 08, 2005 2:51 am
Seb,
Why not put a wanted ad in the car parts section of this forum?
Posted: Tue Nov 08, 2005 2:54 am
by Seb
Good idea!
Just thought I´d try here in Sweden first.
Will do!
Seb
Posted: Tue Nov 08, 2005 3:35 am
by Dennis
I've mounted one from a 75 TS, just as Michael did to his 3.0 (documented on the site). They pull a lot more air than the twin setup and are a hell of a lot easier to come by (and cheaper).
Posted: Tue Nov 08, 2005 4:05 am
by Seb
Hi Dennis!
Sounds like i good idea. How is the fit to the GTV6 radiator? A lot of rebuilding?
Is there a difference between the TS and the 2.5/3.0 fans?
Do you have a link to Michaels documentation?
Cheers /Seb
Posted: Wed Nov 09, 2005 12:36 am
by Dennis
"Cooling problems have been solved by installing this Milano (75) radiator cooling fan - which has proven to work a lot better than the stock twin fan setup. It bolted on quite easily - though a little grinding was needed to allow the shroud to clear the sides - and allow it to fit as close to the radiator as possible. Note that I also needed to grind away a bit of the mounting bracket indicated by the red arrow. As you can see, the aluminium adapter brackets attach to the GTV6 radiator using the stock mounting positions and hardware."
Posted: Wed Nov 09, 2005 12:51 am
by Seb
Thanks Dennis! It looks GREAT!
Is that a stock 75 Milano fan? How does it differ from the TS-fan?
Seb
Posted: Wed Nov 09, 2005 9:55 am
by Jim K
Why not try something like this? The A75 TD setup.
Posted: Wed Nov 09, 2005 10:05 am
by Seb
Well Jim, I would if I had some money to spend on it. I just want to get it working for now. I have a lot of other expenses with hte car this winter. I dod not plan for the fan to be one of them unfortunately.
Are those expensive and are they easy to come by?
Seb
Posted: Wed Nov 09, 2005 10:39 am
by Jim K
For the rad I paid 114Euros (dealer price) but regular price was 175. The twin fans you can get from a used parts store as I did (90Euros) and then rebuild them (no parts required, just cleaning the inside of the motors,smooth out the the collector and brushes, grease the bearings and thats it.
These aluminum rads are very hard to come by now, but the std TD rad should be available new (same size).
Posted: Wed Nov 09, 2005 10:48 am
by ar4me
Who made (makes) that alu rad? I ended up putting a new stock 3 liter rad in my 3 liter milano a month back. Ran well at Oct TT in the CA desert (WSR), but then again, it had cooled down some by then.
Posted: Wed Nov 09, 2005 11:09 am
by Jim K
Its a Spanish subsidiary of the BEHR company (German firm making all kinds of excellent quality rads and thermostats for all kinds of cars)
The box has the p/n AL2031 on it, but nothing related turns up in the net.
This rad has Alfa90 and 75 TD application and the bottom pegs fit the 3liter if you use a 55Ah battery and cut a ~2" V shape notch in the tray. Good idea to enlarge the front sheetmetal window to expose the whole surface and fit a heavier duty 40A relay with bigger gauge wires straight to the battery or starter motor terminal.
Posted: Wed Nov 09, 2005 11:28 am
by Barry
sEB,iM NOW USING NEW 156 RAD FANS ON OUR CARS...damn,sorry.........They work brilliantly and can be set up with 2 speed settings,cost here about 2 grand...
Posted: Wed Nov 09, 2005 12:34 pm
by Seb
OK, thanks Barry!
The 156 has twin fans or is it singles? Do you have any pics?
Seb
Posted: Wed Nov 09, 2005 1:32 pm
by Hippo58
Twin fans, more efficient blade design. More compact setup also.
