Sunracer
clutch removal
Post by Sunracer »
Hi all, I am trying to pull the clutch from my GTV6. I followed the directions in the
Alfetta manual I have but the clutch wont come more than a few milimeters out. I have been reading LOTS of posts an I understand that the throw out bearing is attached to the pressure plate on the GTV6. So I assume I have to disconnect the clutch fork to get it off the throw out bearing in order to remove the clutch assembly. Is this correct? How do I do that? Thanks, Pierre
Pierre
1984 GTV
Murray
Post by Murray »
Pierre the fork will pull off the throw-out bearing.Grab the end of it a pull straight out.It is not actually attached to the bearing it's just the flats of the fork that "ride" on the flat sides of the bearing.
Hope that helps.
Sunracer
Thanks Murray
Post by Sunracer »
I pulled the clutch slave cylinder off and the fork and clutch came right out...sometime it's tough working off an Alfetta manual! Pierre
Pierre
1984 GTV
