BMWs usually have a guibo in the first joint position though, the M3 is different maybe?
TS_turbo
Post by TS_turbo »
Mats wrote:BMWs usually have a guibo in the first joint position though, the M3 is different maybe?
Jarle
Post by Jarle »
Here is a picture from the back of my shaft. The front has the same type of coupling as the back and is attatched to a 3.6kilo alu flywheel.
Alfa pix 015.jpg (210.19 KiB) Viewed 5240 times
Jarle,
Tell us what we all want to know:-
1 Is it all universal joint or a mix of rubber couplings as well?
2 What car is this on, road or race ?
3 Two piece or one piece shaft?
4 Is the vibration (if any) acceptable?
5 Is there any special fitting requirements in terms of angles to cater for the correct operation of the universal joints?
Hope it's not too many questions for ya.
Jarle: Don't tease us with one pic!!!
Jarle
Post by Jarle »
MD:
1: No rubber
2: Track car with licence plates
3: 2-piece with slide part in senter section
4: Acceptable. Engine is fully rebalanced with front pulley and "front" flywheel.
5: Not done aything specific. Have hardly driven the car with this shaft. Hopefully I can give a feedback during July, as the car is under major modifications at the time.
prop.shaftrear 007.jpg (188.09 KiB) Viewed 5198 times
prop.shaftfront 004.jpg (123.79 KiB) Viewed 5201 times
prop.shaftfront 003.jpg (113.32 KiB) Viewed 5200 times
prop.shaftfront 002.jpg (123 KiB) Viewed 5199 times
prop.shaft senter001.jpg (174.62 KiB) Viewed 5198 times
