tmundy
Damaged clutch case
Post by tmundy »
Removed today the transaxle complete. While cleaning 24 years worth of crap of it I found some damage to the clucth case. What do you think, should I replace the case or forget about it?
Ta, Tony[/url]
150707 019.jpg (24.77 KiB) Viewed 6605 times
tmundy
Post by tmundy »
Second bit of damage, caused by the brake line rubing I think.
150707 020.jpg (26.17 KiB) Viewed 6604 times
Tony,
These things abound like wild mushrooms.. :D Just replace it with a good used one. Welding it up would cost you more and more than likely distort it..
Yeah, agree w/ MD
even though the crack is in a lower stress area, would definately replace it...
Problem is many people want to sell you the clutch, too and that is more money...in that case, welding might be the better option
tmundy
Post by tmundy »
Thanks for the reply guys. While I have the clutch out do you think it is worth replacing the dual plate (only covered 55,000 miles) with a single plate unit? I have read that this is a good upgrade as it makes the clucth more progressive but am not sure if it is worth waiting until mine is knackered.
Ta, Tony
do it up right, single discs are easier to come by ...
tmundy
Post by tmundy »
And much cheaper. I use Highwood Alfa here in the UK and they quote:
Dual plate £550
Single plate £260
Are any modification required to fit the single plate?
Cheers, Tony
Yeha, the whole clutch pressure plate throwout bearing assembly is different, but fits right in...
