Got a strange one.
On the top left hand side of the differential is as round thing that is rusty colour. In the first picture below you will see it is reasonably dry. In the second picture taken a day later there is a nice pool of gearbox fluid. Worth mentioning that I drained the fluid a couple of weeks ago. Any idea what this thingy is?
Thing on top of Diff
- Thing3 small.jpg (22.83 KiB) Viewed 6496 times
- Thing2 small.jpg (28.1 KiB) Viewed 6497 times
Say what? out the sides?tmundy wrote:It is sticking up about .8cm above the surface of the transaxle. Does it breath through the top or from the bottom (out the sides)?
I think you need to take some pics that give us the general overview because it sounds very confusing.
early transaxles stick out a little bit roughly .8cm as u describe wheereas later cars stick out alot more. it is an oil breather and if oil is spilling out id have a guess and say u put too much oil. clean it and make sure it is not blocked.
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
My car is an 83 (MK3 I believe), would you class that as early or late.early transaxles stick out a little bit roughly .8cm as u describe wheereas later cars stick out alot more.
Funny thing is I drained the oil about two weeks ago before removing the transaxle. The gearbox is curently empty. How does it come of, is it screw fit?
Thanks, Tony
