I've noticed I'm missing all the longer bolts that hold the De Dion cross member to the body of the car. If anyone has one available to measure so I can source some new ones, if be eternally grateful.
Is that car an Alfetta ( meaning 4 cylinder)? I notice the deDion tube is bolted right to the body. On a GTV6 or a Milano there are spacers between the crossmember and the body.
It's a GTV6. I am missing the spacers as well, trying to source a set or get measurements so I can make some.
Bolt length of around 95mm should do the business but you should try and get the genuine ones as they are specifically made for this purpose that make them self locating at the start.
