Page 3 of 6
Posted: Sun Dec 19, 2004 7:30 am
Ok, snapped some pics today...
Thats the good stuff!
Posted: Tue Dec 21, 2004 5:21 am
Two days and not even a comment, that's unusual...
Posted: Tue Dec 21, 2004 8:32 am
by 81GTV6
Mats we are all green with envy
I always liked that little red bugger. From what i hear the engine doesnt have many mods. You cant let it stay like that can you!? What are you going to do to it, TS, Turbo, c'mon tell tell!
Posted: Tue Dec 21, 2004 9:49 am
Yeah, next years mods include new crank seals, front and rear...
No engine mods planned actually, I need to stay in my class.
What!?
Posted: Wed Dec 22, 2004 11:23 pm
by junglejustice
Still allergic to the V6 Mats...?
So, we just ordered two shift-kits from Alex Jupe... (Reduces the 1-2 throw by 22mm from 90mm to 68mm...) and gives it a more positive feel. Dunno.We'll see. 150 UK funny money plus shipping...
Nice guy too.
We'll re-bush the isostatic linkages at the back, lighten the gears (ALL of them) by back-cutting and shot-peening, new syncros and pray to the Alfa Gods....
Posted: Thu Dec 23, 2004 3:00 am
Well, if someone gave me one of those puppies I'd give it a good home but I need to be able to buy tires, fuel and pay for transports and fees too...
Racing is fricken expensive and the hardwares are mostly not the expensive parts.
Be sure to post feedback on those shifter kits, jj!
Posted: Thu Dec 23, 2004 8:21 am
by Plastic Pig
I can do that: I have one on my GTV6. Mine still needs to be adjusted to make it easier to reach (the seat is further back than usual as I'm over 6 feet tall). However, the throw is much shorter and the change is more precise, though the latter could be because the linkage has recently been rebuilt.
It's certainly much better than before and much better than on my 75 (which, for a 75, is pretty good).
See
www.alexjupemotorsport.co.uk .
Posted: Thu Dec 23, 2004 6:54 pm
by Zamani
I could not find how the kit looks like? Did you extend the shaft below the shifter's pivot point ? That would shorten the throws.
Posted: Fri Dec 24, 2004 6:14 am
Tnx, Plastic Pig.
Zamani, yes lenghtwise thet is true but it will be the same side-to-side. I have this on my car and I don't care about the little longer strokes with my long gear lever.
I bet one won't change gear faster if you reduce the storke 50%...
Posted: Wed Dec 29, 2004 10:29 am
by Hugo
If I may add my tuppence to this thread. I found that having the prop shaft balanced made a sizeable difference to the quality of the change- and indeed the smoothness of the car generally. Other mods included having bronze bushes fitted.
I would also comment that at 6' 4" (195cm), I find that having a RHD makes it so much easier to heel and toe (there is more room for my size 45's). Indeed, for me, half the fun of the GTV6 is the fun of hearing the blips on down changes- such that I have never had a problem with down changes. For what it is worth I also had the pedals bent slightly so that there was a bit more room.
I have to say, however, that my experience is strictly limited to road driving. I also admit to the fact that I always treat the 1st to 2nd shift with extreme delicacy. So if there was a realistic solution that allowed one to slam it through, I would be interested to hear about it.
Hugo
Posted: Wed Dec 29, 2004 8:00 pm
by MerrilGordon
Say Junglejustis, maybe a few items that might be helpful. . .
Check out
alfaracing@yahoogroups.com for some info on reducing the rotating mass of the driveline. Specifically a clutch assembly from Richard Jemison. A 4-puck affair of about 5.5" in diameter and I believe the necessary pressure plate and other components. Someone commented that while a little grabby, it was still quite streetable.
Here is a comment from Mike Cudahy who races a modified Alfetta in SCCA. "For those that are looking to spend some money to make their car faster, this modification was the most dramatic change I've made to the car in the five years that I've been modifying it. Richard's clutch assembly weighs 12 pounds from input shaft to release bearing, and is 5.5" in diameter. Compare this to the enormous 26.5 pound Milano clutch with the aluminum Porsche pressure plate, and you get a loss of 14.5 pounds of reciprocating mass.
That's freakin' huge, and the race proved it. My lap times improved by 2.5 seconds a lap, and the car felt completely different from the moment I hit the start button. Consequently, when you remove that much weight from the driveline, the car starts a lot easier."
I expect you've already lightened the front flywheel JJ.
Although maybe too new to go into production yet, there is Al Mitchel's carbon fiber drive shaft. See
http://www.realemotorsports.com/rd/winter04/cfshaft.jpg
and
http://www.realemotorsports.com/rd/wint ... shaft3.jpg
These improvements may not help the shift linkage itself, but I figure reducing the rotating inertia that much, the load on the synchros and ultimately the responsiveness of the shifting and drivline will be substantially improved.
What do you think ?
Merril
Thanks Boss,
Posted: Thu Dec 30, 2004 10:37 pm
by junglejustice
For alfaracing, that's an email... not a website...?
Posted: Fri Dec 31, 2004 6:34 am
by 4SFED4
Just go to Yahoo! Groups and search for "alfaracing", dont' let the "@" confuse you jj.
-Brian
Posted: Wed Jan 05, 2005 12:06 am
by ingegnere
Hi Guys!
You all have so much experience as I see, so probably you can help me.
My friend has a workshop with CNC machines, and a couple of weeks ago I gave him a set of syncro unit and asked him to manufacture some rings. The only thing we cannot deal with yet is material quality.
Do some of you know what kind of steel and heat treatment did Alfa use in their rings?
Or do you have any suggestion for material quality and heat treatment? The goal would be to fabricate better quality and longer lasting rings at first, and maybe sleeves and other parts later.
Does anyone have experience with titanium rings? Would the material's sliding properties cope with the original sleeves? This question is more theoretic since I do not know the price of titanium yet, but if it would work I would maybe go for it.
Any answers are welcome!
Posted: Wed Jan 05, 2005 6:42 am
by 4SFED4
Wow, what a project! I will copy your post to a friend of mine who is much more educated in metallurgy than I am and see what I can learn.
-Brian
