Do you have drivetrain problems? Are you planning on a 500Hp engine build?
WHY do you wanna mess with that shit? IT WORKS GOOD FOR ALMOST ANY MOD YOU CAN THINK OF. God damn it...
It's like spending 2000USD on a perfect replica of the floor sheet metal in stainless steel, only you will know it's there and you will gain
absolutely nothing in terms of performance. We are talking 1/100 of a second per lap, can you drive that well consistantly?
I would pay for a thinner front window before a CF drive shaft, or rewire the car with lighter wires...
If you really wanna improve how the car drives, move the engine right up to the firewall (then hit it with a sledgehammer and move it again), move the seat back to the cross member and down to the floor (move the pedals and steering wheel if you have to), fibreglass dash, ditch std instruments, get a new roof panel if you have a sunroof, throw the e-brake in the bin, make the exhaust out of 0.5mm steel tubes, 3Kg flywheel, 4" clutch, lighter starter motor, run it on a battery instead of having an alternator and so on...
I can go on like this for a while you know.
But DON'T get a CF driveshaft!
