Clutch master fluid
Posted: Wed Jun 07, 2006 10:56 am
Be careful of the type of fluid you use. I picked up some standard brake fluid from the auto store, put it in my clutch reservoir and within minutes, my clutch pedal felt like bubblegum. Fluid leaked out through master into pedal box overnight. I think this new brake fluid dissolved the previously fine master seals!
Unfortunately, it was a few months ago and I dont remember the name...
Which type is a good compatable clutch fluid?
Do you guys use different brake and clutch fluids? (at one time, Alfa had these running off the same reservoir.)
Presently, I have separate reservoirs..
