75 GTA
Clutch issue on 75 2,0 TS
Post by 75 GTA »
Something strange has happened.
I bought a clutch disc for my TS and when I took the old one out the sizes didn´t match at all!!!
The new one has 215mm and the one I took out was 200mm :shock:
How can this things happen?!
I had to refurbish the old one with new Ferodo rings and put it back in place (works perfect though).
Now what am I supposed to do with the 215mm one? Is it the wrong one or is the 200mm not from that GB in the first place?!
I´m quite confused and I´m not sure if I can take the 200mm back to the store.
What size are yours? (75 Ts guys especially)
75 TS Road specs
75 TS Gr N
146 TS
It should be 215 mm
75 GTA
Post by 75 GTA »
That´s what I thought :?
Now what happened here?!
Is the gear box from another type of engine? (IE 1600/1800/2500/3000 ?!)
I just hope the LSD diff is there :(
75 TS Road specs
75 TS Gr N
146 TS
75 GTA
Post by 75 GTA »
How can I see where this gear box is from?
75 TS Road specs
75 TS Gr N
146 TS
sira
Post by sira »
200 mm clutch was on 1.6 gearbox, all other models has 215 clutch, I have 200 cm clutch, and it's imposible to find.
75 GTA
Post by 75 GTA »
...so is it possible that the previous owner put a 1,6 gearbox with the 2,0 LSD ?
75 TS Road specs
75 TS Gr N
146 TS
Or he used a 1.6 clutch with a 2.0 box.
What I'd do for an economy flex track solution is:
Lighten the 1.6 flywheel (it has lower inertia than the 2.0)
Use a sintered clutch disk. This should be OK for 2.0 engines.
75 GTA
Post by 75 GTA »
I just talked to the previous owner. :x
The thing is that he throwed the complete set (Rear flywheel, clutch disc and actuator) from a 1600 into the TS Gear Box.
He thougth it would make it rev easier since de flywheel is smaller. :roll:
The only thing that got faster was the clutch disc wearing process :evil:
75 TS Road specs
75 TS Gr N
146 TS
He's RIGHT. Read my prev post.
75 GTA
Post by 75 GTA »
He would be RIGHT if the car wasn´t ment to be raced as he is...
I´m quite sure this could work fine on a road going car but this is not the case.
Maybe I should go for a swap between my two 75 and swap the stock GB into the race car...
But first...let´s see if it holds the pressure on track.
PS:
Thanks Micke :D
But what is a sintered disk?
75 TS Road specs
75 TS Gr N
146 TS
I have a 4-puck clutch meant for the V6 gearbox in case you are interested. It is still sprung so it should be drivable even on the street.
75 GTA
Post by 75 GTA »
Hi there Austin Pow...argh Zamani :D
I would be very interested but it would cost a fortune to ship it here in Europe :evil:
75 TS Road specs
75 TS Gr N
146 TS
Does it? I can ship via regular mail and it shouldn't cost much.
Remember Euro pwnzzzz the US dollar these days.
Something like this:
http://www.performatek.com/Alfa/Drive%2 ... rung02.jpg
They should be available locally or a racing shop can make it from the 1.6 disk.
I have a 2.0 group N pressure plate from Sachs. Maybe it is available for the 1.6 as well.
BTW, shipping isn't that bad as long as you use a slooooow one. It takes ages to get the stuff over alaska and siberia but the price is right.
75 GTA
Post by 75 GTA »
Oh I see!
I will ask my local Alfa racing shop for the complete set (Gr. N sounds pretty reasonable for me).
75 TS Road specs
75 TS Gr N
146 TS
