Differential or Transaxle ?
Posted: Fri Aug 24, 2007 12:32 pm
by Cassin
What is the technical difference between a differential and a transaxle ?
Posted: Fri Aug 24, 2007 3:03 pm
Cassin
An Alfa transaxle combines the clutch , gearbox and the
differential into one composite assembly and the
differential (with or without limited slip) drives the rear wheels via the output shafts and axles .
In conventional rear wheel drive cars a
differential receives the drive from the tailshaft (or prop. shaft) and transfers that drive to the rear wheels to move the car.
In a front wheel drive car, the separation of these components is less clear because the housings may visually confuse these functions.
For an all wheel drive car, there are two
differentials, one for the front axles and one for the rear along with other parts that make all this work.
To my knowledge, there are no transaxle all wheel drive cars ( but I have been wrong before
Pick up any workshop manual and look at the shematics that will clearly describe which part is which.
Posted: Sun Aug 26, 2007 9:18 am
by junglejustice
164 is a transaxle.
164 Q4 would be an AWD transaxel then (at least at the front...)
Posted: Sun Aug 26, 2007 10:10 am
Or a transaxle with a PTU.
Posted: Sun Aug 26, 2007 10:30 am
by x-rad
PTU? does that equal a PTO..like farm equipment
Posted: Sun Aug 26, 2007 11:16 am
Pretty much the same thing.
Power Take-off Unit.
