Hi,
i have started rebuilding a gearbox for my gtv.
looking at both of my manuals there are two different clearances specified for the distance between the selector fork and selector hub.
one says 0.2mm-0.5mm the other says 0.7mm-0.9mm.
does anyone out there have any idea why they may be different.
the gearbox im building is a 75 ts if that makes any difference.
cheers
Ben
gearbox rebuild question
1962 Giulia Ti Race-car
1969 Giulia Super
1987 GTV6- new race project.
1969 Giulia Super
Re: gearbox rebuild question
Measure them all, if they look alright and have the same clearances disregard the manual.
When you fix the forks back on the axles make sure everything is in the middle, i.e. shift gate/axle and fork.
thanks Mats.
they all have close to 1mm free play.
is this too excessive?
have you had forks built up before?
does it make much difference to the shift?
it is for a race car so want it to be good.
cheers
Ben
cheers
Ben
1969 Giulia Super
1969 Giulia Super
I have honestly never measured.
I'd slap it together without hesitation, too much theory can make your racer a garage ornament...
