Bruce
75 3.0 litre to 2.0 litre clutch unit conversion
Post by Bruce »
.. is it a straight swap or is there tomfoolery with the transaxle internals?
xrad
Re: 75 3.0 litre to 2.0 litre clutch unit conversion
Post by xrad »
what is the benefit of the change?
It's cheaper or he has one laying around... 8)
Or is it because the pulling throw-out bearing is NLA?
Bruce
Post by Bruce »
.. it's cheaper AND I have a few laying around.
xrad
Post by xrad »
ahhhh...
but I still don;t know the answer about the swap...
PietereQ
Post by PietereQ »
No it's not straightforward. Unless you have 2,0l clutchcover and 2,0 slave. Then you can bolt it on to the tranny, well take al look here pics are worth thousand words... :
viewtopic.php?f=9&t=3167
ps. Ill add myself to the asking audience. WHY? You'll certainly enjoy you 4 banger clutch for much shorter time on a V6. Been there done that :D
Bruce
Post by Bruce »
I wanted to know if the transaxle input shaft would fit into the clutch assembly and housing of a TS unit without modification. I am aware I have to change the slave cylinder and other bits and bobs, and I know it won't last as long as the original but I have the opportunity at the moment to do some experimentation - what's 15mm and 3mm between friends?
Reason? I want a much lighter clutch pedal.
AFAIK all input shafts on all Alfetta production cars have the same clutch interfaces.
You will however need the correct pilot tube for the throw-out bearing you want to use.
Bruce
Post by Bruce »
.. same clutch interfaces? You mean all the flywheels are the same?
Bruce wrote:.. same clutch interfaces? You mean all the flywheels are the same?
On the input shaft, yes.
