xrad
LSD clutch disc
Post by xrad »
Anyone have a source for new standard Alfa milano LSD clutch discs?
Do the Spider discs fit?
Re: LSD clutch disc
Post by la_strega_nera »
Vague recollection that yes, it's the same discs.
1966 GTV
1982 Suzuki "Bathurst" Katana
xrad
Re: LSD clutch disc
Post by xrad »
Thanks for reply! Anyone else?
I remember reading that somewhere a few years back...but don;t know for sure..
Re: LSD clutch disc
Outlets in your country that sell ZF components should list them.
xrad
Re: LSD clutch disc
Post by xrad »
Thanks MD
xrad
Re: LSD clutch disc
Post by xrad »
xrad
Re: LSD clutch disc
Post by xrad »
MD, I emailed the guy above but his respose was:
"ZF Services Australia, is not responsible for the USA market, please contact your local ZF dealer close to you ."
Of course, no one here has these parts as no alfa dealer. I will try small alfa shops and see...
Cheers
xrad
Re: LSD clutch disc
Post by xrad »
I bought three sets of shims (1.9,2.0,2.1mm) for LSD from OKP Munchen on Monday and they were at my door today (that is 4 day from europe to USA!!) wow, excellent service. Hope they fit!
Still need to find the friction discs...
Re: LSD clutch disc
Have you tried ZF's home ...in Germany i think?
xrad
Re: LSD clutch disc
Post by xrad »
yep! My email is being kicked around and hopefully, it will find the correct department.
xrad
Re: LSD clutch disc
Post by xrad »
found a set.
Re: LSD clutch disc
OK Mr. Brevity, Care to let anyone else in on where you finally got what you needed?
xrad
Re: LSD clutch disc
Post by xrad »
Dean at Trail Alfa had a set of original Alfa.
Found some at Performatek.(don;t know if original)
OKP Alfa parts in germany ( I bought the shims here, superfast!!! shipping)
max
Re: LSD clutch disc
Post by max »
xrad wrote:Anyone have a source for new standard Alfa milano LSD clutch discs?
Hello, :D
I will be able to sell some of the friction discs and also the washers inbetween in 3 thicknesses.
(1,9mm 2,0mm, 2,1mm)
If you would need discs: :arrow: E-mail or PM
Regards, :wink:
Maxx
xrad
Re: LSD clutch disc
Post by xrad »
Thanks Max. OKP had what I needed.
