Rear engine mount difference 2.0 vs 2.5
Hi guys,
Is there a difference between the rear engine mounts of the 2 litre and the 2.5 litre V6?
If so, what is this difference? Some photos please.
Recently I learned there is difference between the Alfetta/105 rear engine mount and the TS engine. The TS has a core reinforcement panel and provision for fitting a small starter motor.
I am hoping the V6 is similar but with a larger central opening for the bigger coupling. At least that's what I am expecting.
Re: Rear engine mount difference 2.0 vs 2.5
Are you talking about the aluminium piece or just the rubber?
the alu piece is different, has complete different mounting points. v6 en I4 can't be mixed.
4 cilinder alu piece with room for big donut is found on 1.8Tb, they use the big donut. :wink:
EXCELLENT info ! Thank you.
I was about to start thinking how I could cut the front section off the V6 housing and graft it onto the inline four rear section to gain some internal room for the bigger coupling I want to use. Seems like its been done by the factory. Great !
Not so great-where the hell am I going to land one of those suckers in Oz?
OK lads, anyone has one of the 1.8L ex turbo rear engine mounts for sale??
Maybe I need to contact the Greek Mafia to knock off the one JK is using :mrgreen:
