Isostatic Interchangeability?
Posted: Sun Mar 27, 2011 5:46 pm
by Terafrost
Does anyone know if isostatic linkages are interchangeable between models?
The one in my GTV6 is in need of repair and I would like to rebuild a spare I have from an Alfa 90, rather than have the car on stands for a week whilst I search for parts.
Any hints would be brilliant.
Cheers
Re: Isostatic Interchangeability?
Posted: Fri Apr 01, 2011 6:17 am
by xrad
pretty much just measure up the components against one another.
They are the same for 75 and gtv6.....
Posted: Sat Apr 02, 2011 9:03 pm
by Terafrost
Thanks for the reply, Xrad.
I've since ascertained the fact that they are the same, I just wanted to try and avoid having it out of the car for weeks until the rebuild happened. She's my daily driver
Posted: Sun Apr 03, 2011 8:46 am
by Guran
The linkage is shorter on a gtv6 than on a 75. But it's just a matter of cutting and welding...
Posted: Tue Apr 05, 2011 8:19 am
by xrad
ummm ... Guram, by 'linkage' do you mean the long 'shift rod' going from the stick to the iso-links..
or do you mean 'iso-linkage'
the 'shift rod' is definitely longer in the milano(longer wheelbase), but the iso-linkage is the same.
Posted: Sat Apr 09, 2011 3:58 am
by Guran
I meant the long horizontal shift rod which is longer due to the wheelbase.
The linkage part are the same.
