DaveH
Post by DaveH »
That's v interesting!
What is the thickness spec of the moly spray?
ingegnere wrote:Mats
They're from the old box.
I took them to the machine shop where the surface was cleaned from the worn material and re-plasmasprayed with molybden.
We didn't try the box yet, but we expect it will behave as new. :)
I meant the pressed on cogs that actually engage the gears, looks like you changed from really worn ones (worn.jpg) to new-looking ones (wornnot.jpg). New or good used?
ingegnere
Post by ingegnere »
Sorry, I really misunderstood.
Those teeth are good shaped used ones from my other boxes.
Unfrortunately I'm getting run out of them. :?
Dave
Thickness is 0.1 and 0.15 mm.
I've had these two sets made, and combined them as a function of syncro sleeve wear.
'The GTV': '83 GTV6; (summer)
