- Mark Walshaw
Clutch plate refurbishment
Anybody know where I can have my clutch (2.5)plates refurbish in S.A. Gauteng area. Every think is still in good condition, just one of the linings decided to come adrift.
Re: Clutch plate refurbishment
Norbrake in Benoni did mine , but must check the have correct thickness . When you bolt it up if the rivet on the pressure plate is flush then your clutch won't release . However if you can get correct thickness lining then you can skim the intermediate plate by the difference .
I will check what new plate thicknesses are in my file . Kev strapp should also be able to help you out .
