Best headers to use?
Im pondering if I should get a pair of headers to top off my 164 12v conversion. I am leaning towards the IAPs, what else is out there?
CSC?
CSC? I have a set in my car...
These are powdercoated. I actually tried a set of IAP headers on my 3 liter and found it impossible to use since they rubbed on the engine webs and the starter. I'm not sure if this was a problem only with my set though. IAP said they would work fine on 3 liter GTV6 engines, but I had to return them eventually. The CSC headers fit well.
The only issue I have had is with a failed flex pipe - I had that replaced and so far, all is good again.
I got mine from PerformaTek but EB Spares in the UK also stock them.
Cheers,
Cheers,
Michael
1981 GTV6
1981 GTV6
IAP headers
The IAP headers are a pain... I know I got a pair on my car. There's almost no starter clearance and the fit was NOT great. They already eat a starter motor... I had to get a heat sheild custom made... Hopefully it'll be all good from now on. And the surface finish did not last long.
For my track car I'll be getting CSC headrers.
n
n
I have the CSC's on mine, with Port & Pol heads, oversized valves, but I am also running cats for emissions, we did a dyno run last night, and two friends with '85 & 86 GTV6's stock except they have no cats, and we all ran about the same numbers, I think I was middle in HP and Torque, but I have the smoothest lines. HP was with in 4 of each other and Torque was with in 3 of each other.
- 17% loss through transaxle
- Dyno Run.jpg (228.02 KiB) Viewed 17473 times
Nice smooth tourqe curve you've got there Sam, with a bone stock 2.5 some years ago mine showed 131bhp atw also at 5500rpm (dropped a hp at 6k) So it looks like your motor is fit and well.
I have the CSC's on a 3.0 in a GTV6, for anyone thinking of doing the same fit was excellent, althought very tight around the starter heat shield. Haven't dynoed it yet, but I'll post it when I do !
Dave, that's cool that you ran 3 up at the same time.
Assuming they are all similar gearing is there much difference in how they feel on the road?
The HP curve is really smooth. Can you post the others? I have seen some pretty shaky ones out there.
I have Shankle headers on an 85 that I did not have to fit. They are pretty close to the bellhousing and have clamps (jubilee clips in UK English, can't think of the US name) that I am sure are there to help keep them from interfering with the engine.
Jef
www.motozane.com
www.motozane.com
Dynonight
Jubilee clips = hose clamps. I'm Irish, so I also forget the isms. Trunk? Hood?
Yeah, it was great to run 3 all at once, same night, same dyno.
I have driven Sam's. His is a beauty, prob the best cared for higher mileage example you'll ever see. 1st thing I noticed was that his higher tyre pressures worked so much better than my 'factory recommended settings'. I now run 30psi all round and am still experimenting. He has Toyos, I have Kumhos. Both great tyres, can't tell if there's much of a difference between them.
Other than the tyre issues, I think both cars feel very similar on the road. Our gearing is different (we've had endless discussion about this) - mine is travelling @ 80mph @ 4k RPM. Year of mfg of mine is late 84, I guess the diff installed then may have been the 4.11. I have the link to that info somewhere...
One thing I have learned is that if your 'box doesn't work right, you're really not enjoying your Alfa. Sam and I overhauled my box, which had the usual impossible-to-downshift-into-2nd problems. Now it works perfectly. It's non isostatic, with an improved pivot fork bushing (roller brgs). Before the overhaul I was only enjoying the car 70% of present. The car was a bear to drive. Taking Sam's for a spin really underscored that.
We'll post some more dyno graphs in due course...need to fire up the scanner on Monday and do that.
Oh, Sam mentioned the Italian tune-up. It was amazing how much cr@p was exhausted from our cars on our first runs. After the initial cleanout, the second runs tended to produce more power. From now on, I'm going to blow the cobwebs out every once in a while...I promise.
That is mostly what I have thought about all day, since I am no eletrical engineer (like Dave), the Gotech sounds like a good option, I would like to talk to someone who has fit it to a 2.5. Looking at my chart, I think the AFM is the hold up in mine, I should have no problem with exhaust flow. It was interesting, we popped off my air filter for the last run and I lost 2 hp and picked up 2 ft/lbs of torque, the chart I posted was the 2nd run.
I think to confirm what has been said many times on this forum, a stock 3.0 Verde put down 170hp at the wheels, that truely is the best bang for the buck, but I will continue to work on my 2.5.
