Let's read between the lines and put the puzzle together here....Barry stole and took the engine out of a Beemer, and he's going to put modified TS distributors on it to make an engine for a 4wd Russian submarine which Micke will sell to the Finnish navy with Zamani being the middle man...what a mixed up bunch! Sounds like something only the 4 Stooges would try!
This is a preview of the next James Bond movie!
dammit....JimGreek wrote:Let's read between the lines and put the puzzle together here....Barry stole and took the engine out of a Beemer, and he's going to put modified TS distributors on it to make an engine for a 4wd Russian submarine which Micke will sell to the Finnish navy with Zamani being the middle man...what a mixed up bunch! Sounds like something only the 4 Stooges would try!![]()
when james will stops with thoses bimmers...?
Isnt theses aston martins that are supposed to be used ?
2 stroke addict
Ha,neither would I ,Priscilla-Queen of the desert!!!!MD wrote:I'm not going to own up to anything..
The Beemer engine is mine...Its earmarked for one of my Giulietta's..Not my E34..
The auto box attached to it was sold a while ago..
The ts distributor is earmarked for a.......TS !!
Zman,Yes,4x4 x5...Same as e39 engine..Zamani wrote:Looks like a 4WD tranny there.
Is it really going in your Giulietta or E34?
and yes,Its earmarked for my silver car...minus all the plastic...they look rather good in the raw as such..
Friend of mine races off roads powered by these ..
Mike,Australia`s most famous export was the movie,Priscilla!! That and John Farnham..hehe..and porpoise spit..HAHAHA...!.(Murial`s wedding.)
Jim,You is da man!!
The dizzy mod as pioneered by his excellency,Greeceball,is tremendous.
Ive now got it down to such an art that I can convert a std one in about 3 weeks...no,actually its a day.
Jim,Ive changed the two green wire thing to just one,I then use a single double pole wasted spark coil!
Two outlets from coil to two inlets on dizzy!
Works a treat.
Works a treat.
- DSC01813.JPG (146.5 KiB) Viewed 7306 times
- DSC01815.JPG (135.43 KiB) Viewed 7306 times
- DSC01821.JPG (152.84 KiB) Viewed 7306 times
Was as rough as a bears ass...!Alfettish wrote:sounds very crisp
It cleared after a few seconds...Id killed the camera as I needed to run around and check oil pressures and stuff..as you can see from the excellent paramount quality of the vid..
