Sporttunergtv6
No it does not! The weight transfer is identical unless you have found a way to lower the center of gravity of the car with that thing. Before you say it keeps the CG lower because you're holding the rear down I'd say that files under incredibly low/possibly imaginary prosSporttunergtv6 wrote:maybe i just got used to it. it keeps weight transfer down...
Micke: That was weird, posting almost at the same time...
Wires, yes, to keep the springs from falling off because the shocks were too long i.e. the force on the spring when the wire came into play was close to 0.
Micke: Nah, I was typing slowly because I had a coffee at the same time.
Sporttunergtv6
The wire thing Mats used is a common practice for the rally crowd. This week I started prepping the 75 1.8T for light track use and this spring issue came up when I removed 1.5 coils from the nice Harvey-Baily springs. When the car is on the lift and the DeDion hangs from the shocks, the springs are lodged on the top (I slid a suitable space-age sleeve on the 2 top coils = garden hose
) and the spring leaves the bottom perch completely. When it comes back down, it doesn't go in the right place! I don't like the wire solution so I'll make 2 large plastic cups ~2" high (with holes to drain water!)to bolt on the perch, ~same ID as the spring. I've seen this work before, no problems. A far better solution would be to modify the Bilsteins by shortening the rod ~2"... I wonder how easy that is on a lathe...it all depends on being able to fit the whole shock on, without having to disassemble it! What do the experts say?
Jm K.
Jm K.
- Maurizio
Have done this years ago for a VW front shock. Works great, if you have access to the right tools! Grind of 2" and cut new thread. Be sure you don't damage the grinded surface of the axle where it has to seal.A far better solution would be to modify the Bilsteins by shortening the rod ~2"... I wonder how easy that is on a lathe...it all depends on being able to fit the whole shock on, without having to disassemble it!
A common 105 mod is making a tube to relocate (move up) the upper shock mounting point.
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
or just buy the RS version, same shock just shortened rod...
But yah, should be possible to shorten it without disassembly, mind the heat transfer though.
And of course, no clamping on the part of the rod that stays on the shock.
Mats, added some lathed spacers on to the rear shocks(25mm) to give me about 45mm of droop. No problem with springs relocating off there seats. Had very good racing today with no problems. I have also noticed that my rear brake lock up problem only occured on a particular straight which is more bumpy than usual through the braking zone(purposely done- no its not a motocross track).
Problem solved and thanks for input.
I will put pics up of a 'cup' I made for the rear springs(not RS) on the 24v as this was a problem for road use only.(springs coming out seats).
Pic from track.
Pic from track.
- IMG_2398.JPG (55.2 KiB) Viewed 8157 times
You guys dont know it yet but Kevin deserves some serious applause here...The heads were removed from the race engine a few days ago as we all know from the pictures..
He put them back on and started the engine...A belt pulley then came loose(we've all done something like this when working under pressure and a deadline...
)Bent valves and a holed piston!!!!!!
This guy rebuilt this engine in one day and then went racing on Sarturday!!!!!!!!
Nice one Junior!!!!!!!
