Hi Gang,
In the process of replacing rear brake disks and pads, I noticed the halfshaft spacer and rear disk M10 socket head bolts were pretty beat up and rusty. I was thinking of replacing them with a high tensile stainless set of bolts but I'm having trouble trying to locate a vendor that makes them in this size and pitch (M10 with 1.0 pitch). I know ARP makes a very good quality stainless fastener but not in this size. I guess we could always use a coated bolt if all else fails. Anyone have any luck with other vendors / manufacturers?
thanks
AlfaBeta
Do remeber that stainless fatigues very quickly.I would not use stainless in wheels,brackets etc..unless they are very thick..
Use the original zink and yellow Alfa bolts...these are plated,not dipped...
I totally agree. Stainless also relax the tension in the screw a lot, so you may have screws coming loose and such. Use the std screws, they are the right bits for the job. Very critical area I would not mess with.Barry wrote:Do remeber that stainless fatigues very quickly.I would not use stainless in wheels,brackets etc..unless they are very thick..
