Cassin
Wanted: Original speakers/ frames for door speakers
Post by Cassin »
I'm looking for an original set of speaker frames for the doors of an '86 GTV6, with or without the little speaker itself. Those speakers were pretty terrible, and I've replaced them with a serious pair in the enclosures in the back seat. However, I'm looking for a "cosmetic" fix to the broken frames and missing fabric covers for the tiny dead/damaged front speakers.
If anyone has another cosmetic solution (short of replacing the entire door panels) I'd be most interested in hearing about it.
Richard
GTV6 Speaker.jpg (11.63 KiB) Viewed 8539 times
'86 GTV6
Alfa GTV6 NZ
Post by Alfa GTV6 NZ »
to my knowledge there was no factory speaker in the front door.
each country/dealer just put them in where they thought best.
I believe this is true as i have seen may different locations and i had found some virgin door cards off a junkyard gtv6 that had no holes at all.
should be fairly cheep and easy to take the door cards into an upholsterer and get the lower black section replaced.
