They even have the sliding junk on the E46 CSL I believe. It's the first part to be thrown in the bin as they can't perform as well as needed.
Here Iceman..read this..Mats wrote:They even have the sliding junk on the E46 CSL I believe. It's the first part to be thrown in the bin as they can't perform as well as needed.
"Found this info reading an article about the Z4M Coupe on the Winding Road website. Interesting:
"For everyday drives, the compound brake system with single-piston floating calipers is fantastic. On the track, however, there is apparently a strategy to keeping brake fade to a minimum during long hot sessions. Advises Gerhard Richter, head of development at the M division: “You should take two laps to build intensity, then do four or five laps very hard. After that, take one very easy lap to cool off the rotors and then you’re able to drive as hard as you like for as long as wish.” We did this and, lo and behold, it works."
http://www.windingroad.com/features-page/bmw-z4-coupe/
It's time to take the Schnitzer M Coupe onto the track so I'm going to give this a try (assuming it applies to all M-Car brakes).
There's also a good write-up on the new M3 with a spine-chilling video clip of the beast in angry mode. They're using fixed cameras and the shot of the M3 roaring through the twisties is pure goose bump material.
http://www.windingroad.com/videos/
Pete,GTA Brembo`s are too big for a 15" wheel..Try the smaller GTV Brembo ,that will fit with a smallish disc..
Pic is GTA Brembo`s for my new Giulietta.
- DSC00135.JPG (154.54 KiB) Viewed 9147 times
brookstroutr
Pete,trust me,they were meticulously put down on that bonnet.Not a blemish..
I would look at BMW E30 front discs..Ive used them with Volvo cal`s before and they are very good.
Thanks guys, helpful and infrormative as usual.
But, I have dug through catalogues and found out that the biggest rotors available in E30 (M3) were 280mm
Is it worth the hassle to go with just 11mm larger rotors? Or I just cant find the 290mm ones? (which is likely, never been good at finding things
