tonygtv6
Re: Adaptronic...? Dizzy? Adaptronic to the rescue!!
Post by tonygtv6 »
hi GarthW
hope this info helps,some ignition systems needs a resistor between the ecu and the dizzy to help get the timing right.
patzo_3l
Post by patzo_3l »
the model ford is the ford falcon. a very poplular car down here and because of that fact can buy thermostats in all different heat ranges. i just choose the coolest they had which was a 75 degree i think at the time. but like i said a very easy and simple conversion indeed. and cheap to boot. so cheap in fact that you can afford to change to hotter thermostats in the winter and cooler in the summer.
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
GarthW
Post by GarthW »
Hey Tom, will post pics in my other thread soon! :)
Selling 1985 GTV6.
slyalfa
Post by slyalfa »
This is what I use
1987 black Milano Verde
1972 White spider 2000 Veloce
