Re: GTV6 Zender
PietereQ wrote:Yes, no balls no glory Mats, I just have found a perfect seat for my gtv6, harness angle problem - solved: :D
The shoulder straps anyway...
But I think I'm not the only one wondering, is it wide enough? :lol:
ar4me
Re: GTV6 Zender
Post by ar4me »
Suppose we can conclude that Pete is wider than he is tall... :lol: :wall: Love your new seat, even comes with mounting rail.
PietereQ
Re: GTV6 Zender
Post by PietereQ »
Finally home :) Dropped the car in my garage yesterday at midnight.
Since last pics were still work in progress here are few pics of finished job, some rust due to high humidity:
Upper structure...
Few closeups...
And now TO DO LIST:
-Seam welding (and I'll have a few questions about it for you guys)
-buy some dry ice and remove all that bitumen from the car
-paint the interior
-get hold of lightweight dash
-install new brake lines, brake bias valve
-make brackets, adapters for front coilovers
-overhaul (again :evil: ) rear calipers
-lightweight windows
-drop the engine and propshaft in and ready to go
-And new seat.... uhm hey I forgot I already have one :lol:
Re: GTV6 Zender
nice bundle of pipes you have there.. :shock:
If you go for a hydraulic handbrake you can use 105 series rear calipers. :wink: They are exactly the same, only they lack the handbrake system and don't need adjusting.. :)
Re: GTV6 Zender
Giuliettaevo2 wrote: ...use 105 series rear calipers. :wink: They are exactly the same, only they lack the handbrake system and don't need adjusting.. :)
Really??
Now that's interesting! :shock:
Edit, front or rear 105?
Maurizio
Re: GTV6 Zender
Post by Maurizio »
Mats, the rear's of the 105 are the straight fit!
Even the pads are the same :lol:
Re: GTV6 Zender
Now you tell me?? :shock:
Maurizio
Re: GTV6 Zender
Post by Maurizio »
Mats wrote:Now you tell me?? :shock:
:? always though you guys (and the rest of the world) already was aware of this race (because no handbrake) upgrade....
PietereQ
Re: GTV6 Zender
Post by PietereQ »
Ok I have again bunch of questions to you engineering heads out there...
First, im planning of using uniballs in upper a-arms, in place of stock rubber bushings. Thing is in stock version the load is evenly distributed on the shock tower bolt via the bushing sleeve - that is 50mm. The only spherical bearings i could find have puny width of 12mm, just like here:
Uploaded with ImageShack.us
I'm afraid that due to this the bolt is likely to be bent under load. I've been told that using sleeves on both sides of the joint together with the clamping force on the bolt should be enough to get the job done. BS or not? Because I'm not fully convinced.
I was originally thinking of such "extended" uniball:
Yet no luck in finding any such like these.
Any ideas?
PietereQ
Re: GTV6 Zender
Post by PietereQ »
Ok I understand that silence is "yes" as far as the previous question is concerned.
Here's another one, especially to you guys racing in temperate climate. Do you ditch your heaterboxes? It's a few kgs, yet how to fight with foggy windscreen od humid/rainy days, will just an electric fan will be fine?
Re: GTV6 Zender
I threw mine away. Quite a lot of weight.
I have a small electric fan for the sake of rules. Weighs 600 g or so.
For visibility I use an anti fog chemical. Works fine.
If you don't mind spending the cash the best option is a heated windshield.
Re: GTV6 Zender
Hey Micke, how do you get rid of the red mist ?? :D
Mr Pete, Dry ice to remove tar? Buy a 20 cent Chinese* heat gun and a 10 cent Chinese* paint scraper. Heat the sheeting and it comes off in layers like butter..
** perhaps in Europe I should be saying Bulgarian..
PietereQ
Re: GTV6 Zender
Post by PietereQ »
Micke wrote:I threw mine away. Quite a lot of weight.
Great, I too thought of el. fan + chem combo, glad to see someone has already tried and it works.
MD, I finally ended with heat gun, yea and it's Chinese :D funny thing the old factory bitumen mats, were so hard
Ihad to use a chisel and a hammer, to get those buggers off. They came of in nice 2x2cm pieces... Just a few hours and a gargantuan back ache.
Re: GTV6 Zender
I'm not made from bitumen, still hard though... 8)
PietereQ
Re: GTV6 Zender
Post by PietereQ »
Haha :lol:
