xrad
Re: xrad's gtv6
Post by xrad »
It is a good deal. I will check quality when they arrive. Apparently, these are made in the phillipines, but have a good reputation.
check out:
http://www.rotawheels.com/
xrad
Re: xrad's gtv6
Post by xrad »
this website is a real PITA. never works on the first try....
Re: xrad's gtv6
It rarely fails me, strange...
xrad
Re: xrad's gtv6
Post by xrad »
trying something new
xrad
Re: xrad's gtv6
Post by xrad »
I changed some IE settings so that IE8 works with this older website(IE7)...including some developer tool changes....will see...
xrad
Re: xrad's gtv6
Post by xrad »
Works for three posts so far...
Re: xrad's gtv6
I'm assuming the Rotas are 5x100 and you're either going to:
1) modify the holes for 98mm
2) Wobble bolts from Serpent
and
3) Get proper centering rings
xrad
Re: xrad's gtv6
Post by xrad »
Nope. They are specifically 5x98's with 58.5 center bore and 30mm offset for alfa. These were from special order for alfa wheel distributer.
apparently , he did not need all the sets and two were left over (per 18racing). these were then sold on ebay . I bought one set and the other one sold, too...i think (no longer listed)
So we shall see if i got a good deal or not in a few days....
Re: xrad's gtv6
Post by la_strega_nera »
Zamani wrote:I'm assuming the Rotas are 5x100 and you're either going to:
and
Alfissimo carry the same wobble bolts cheaper...
1966 GTV
1982 Suzuki "Bathurst" Katana
xrad
Re: xrad's gtv6
Post by xrad »
DID some engine work converting 164s to gtv6. No one mentioned that you have to drillout about ten bolt holes for the pan bolts. Also, front lower engine cover fits the crank pulley, but needs to be drilled for pan bolts. You can only get 3 out 0f four in place due to casting. Should seal up allright, though..
Received my ROTA rims today.
all I can say is HOLY CRAP, THESE ARE AWESOME!!! They will need a set of deep lug nuts as the capped ones bottom out ...
see pics..
cleaned and ready to go
xrad
Re: xrad's gtv6
Post by xrad »
more pics...blue cause of photo shrink not working right..
extra holes to drill
cleaning and honing
cleaning and honing
7 thousandths off
7 thousandths off
micro polish..dead on blue!
xrad
Re: xrad's gtv6
Post by xrad »
Rim pics:
total weight for two thick boxes and straps and two wheels is 28lbs...so I am guessing each wheel weighs ~13 lbs.
xrad
Re: xrad's gtv6
Post by xrad »
I like these so much, I just bought another set! :D :D
So for the usual price of one set, I have four spares (I tend to drive off the road...)
Re: xrad's gtv6
Very very nice wheelsss, i'll be looking for a set for the Giulie if the price bought here isn't too crazy :D
xrad
Re: xrad's gtv6
Post by xrad »
They ship around the world (from Phillipines)
