PietereQ
Post by PietereQ »
Any luck Kevin? :)
Btw. My uniballs have arrived, I have ordered the ones with ID of 10mm (for stock bolts holding the rods to the chassis). The tread is also M10, which seems a bit fragile to me. Will it hold the beating from all those lateral g's?
PietereQ, the lenght of rod is 44cm long. The uniballs are M12 with inserts where it bolts to chasis. check pics. you can see the bushes I made for chassis side, there attached with cable ties(not to loose them).
PietereQ
Post by PietereQ »
Thanks Kevin, that helps a lot! Still wondering whether to tap the rods or just weld the nuts on the ends. The id of rod is 10.90 mm so I dunno if the grooves of thread will be deep enough for M12, need to check it in the shop.
PietereQ, is not cheaper just to get a complete watts linkage from RS as youre in Europe unlike me with our import duties and freight its cheaper to buy a small car.
Quite excited about the new '' super lightweight '' front bumper spoiler combination for racing or for road. The combo unit is especially usefull for ultra low cars when loading onto trailers. Its moulded off the origional GTV 3.0 SA model front spoiler.
The only ''loose'' part are the side trims as you need to fasten the bumper on sides to body as per origional design. The combo unit is made from two moulds (bumper and spoiler) in order to maintain origional looks.
Check out pics pf progression to get to this point
fortom
Post by fortom »
Man i wish i was that clever to make things like that, Kevin they look great. Still grumpy about the bonnet!!! maybe you need to move to Aussie and bring all your clever stuff with you. Brisbane is magic.
Tom
fortom, i think you gotta be stupid to make parts for a 26year old car. :)
There has been surprising a lot of interest for the parts (rear bumper, front bumper, spoiler, spoilercombo and 3.0 boonet) so a friend of mine has decided to export this stuff from my moulds. This stuff is so light. As julian is now flying to SA on a semi regular basis maybe he can load a whole kit for you. Dont want to talk prices on this link as its not a vendor section but will work out something .
Trying to finish clutch still but got major problem with cnc machine as its cutting concaves which should be convexes. Waiting for help to find problem when downloading from laptop to cnc (corruption of G2, and g3's).
Theunis
Post by Theunis »
Kevin,
Do you have front bumper/spoiler combo and rear bumpers available? Can you please PM me availability and price. I'm in Centurion.
Thanks
T
Hi Theunis, sent you pm.
fortom
Post by fortom »
Kevin that could be a plan, just need to get the car from New Zealand hopefully in the next month and get it roadworthy here in in Brisbane then we will talk.
Cheers
Tom
No problem, look forward to it.
Kevin, you still need to fix your alternator problems?
Sizing down alternators.jpg (116.16 KiB) Viewed 8574 times
Sizing down alternators 2.jpg (126.33 KiB) Viewed 8573 times
Up size pulley 2.jpg (111.02 KiB) Viewed 8578 times
Kevin, you can edit the program in the cnc machine likely faster than you can troubleshoot you cam software. You should be single stepping thru the program on the machine anyway when you do the setup, so just make the changes there. All that should change is the G code and the + or - values. You should see it in the tool path display also.
hth,
Been away for a while but back until end Jan then off to UK. Sofar stripped race car completely to redo roll cage. As I was putting all fiberglass parts on I stripped paintwork and resprayed it in my drive again.
Faaaargh my spraying has got worse. Did a great job last time but now I got a lot of sanding and polishing to do.
Fiberglass panels include bonnet, boot lid,front bumper and spoiler , rear bumper, and doors. Saved 70kg over origional parts. Doors are now 5kg compared to 25kg. Bootlid is 4 compared to 14 kg.
I have re made engine mounts and lined engine up to gearbox. That was fun . Used old block . Pics can only explain that crazy task. Interesting to see how the original mounts were offset ie 3mm and 13 mm between L and R . Oh ,
Put fiberglass dash in , another 5kg but got old clocks as gonna run a few street legal events. They can only fine me for exhaust out side with one box.
Will post pics some time but need to ask question on Oil Temp unit ?
Do I put temp probe on Out line of oil cooler going to bearings so I know coolers is doing job and bearing are getting correct temp oil OR
Put it on in line to cooler so I know that oil is exiting bearings at good temp and I don't have and problems with bearings. I need to assume cooler is doing .
Yeah , put two probes but got one only.
......end Jan then off to UK.
...and you think they are going to let you in !! HAHAAA, fat chance. :D :D
Maybe if you arrived in an "Austin of England", they might. :D
UK Ticket.jpg (76.95 KiB) Viewed 8305 times
Finally after a year I got my engine back in race car. So hopefully work will continue and car will be on track soon. Car is all white at this stage , was thinking of doing some form of retro stickers on it. Not sure maybe Martini, Malboro any ideas?
