Re: 166 24v into 116 GTV
I started some more work on the adaptor. I need to tap the thread into it and Loctite the thread “tube “ in .One can see the threaded section as cerrated edges for it to bite into the aluminium . Also need to drill the recess for the head of the cap screw.
- 5411B934-097F-4563-8CAC-EA0DBF8AF1C2.jpeg (85.99 KiB) Viewed 11939 times
- 1CFC333B-44C4-4B4D-A2B6-84E76CDDA77D.jpeg (89.86 KiB) Viewed 11939 times
- 7EEF481B-F510-4932-A8A6-0D2714861C6D.jpeg (96.44 KiB) Viewed 11939 times
Those are really nice looking adapter plates Kevin!
Guys, I'm wondering does anyone here have cad drawings of the exhaust flanges for the 3.0/3.2 24V? My engine came without the exhaust headers, and I'm having problems sourcing original ones to copy the dimensions from.
I have some spare laser cut flanges for 24v plus the flanges where they join the down pipes . Drop me pm
If you would like you can have a set of 24v 164 headers from me. For free.
First good deed of this year.
Hey Kevin - did you fabricate the threaded tubes yourself or are they available somewhere “off the shelf” by chance??
Considering how slowly my build is progressing I could do with an easy addition to the parts bin
Cheers
Cheers
Hey guys thanks for the offers!
Kevin, sent you a PM.
This is the trigger wheel which presses onto the pulley wheel and bolts for extra safety . If pulley wheel is in good condition there are no problems on distortion of Rubber inside . The pick bracket is bolt on and adjustable. It does have webs for extra strength but adding more ( belts and braces) as any movement or vibration leads to bad signal .
- 3642D0A4-E77C-478C-BACB-EBE243B22D8B.jpeg (101.99 KiB) Viewed 10840 times
- 6D1611DD-8F8B-4FF1-AB6F-6D1E3FB9FE56.jpeg (99.14 KiB) Viewed 10849 times
