Z,You sure??
I dont know of any 164`s with a singular coil pack with wires...All 24v engines for that matter have coil on cylinder setups...otherwise I wouldnt have to spend hours milling and sanding cam covers smooth..............I would be able to buy them......
enzo
Post by enzo »
yes...on the 164 3.0 12V (the 166 2.0 V6 Turbo has the same coilpack)
the first models had a single coil...the others coil packs....should i search one and take a picture?
enzo
Post by enzo »
Brain fade,sorry-of course the 12v came with the coil pack...Im so 24v these days...
junglejustice
Post by junglejustice »
I see a single coil in the first picture of the 12 valve 164 engine bay - like the US models have... I am assuming that the 2nd pic is of a European model that has a coil-pack in there somewhere - maybe underneath that black cover at the back of the "front" cam...?
So again, another model that Europeans got that we did not! All of our 90-93 12 valve cars were of the single-coil variety... All of our 94-95 24 valve cars had 6 ICPs...
We never had any of the 6-pack coil-pack models here...
Barry, right you are; while the new GoTech ProX will run 6 ICPs and the GoTech Pro will only drive the 6-pack variety on its own, you can add individual drivers and run 6 ICPs with a GoTech Pro.
I believe all the 12v MY -93 and on was of the coilpack/wastefire variety, possibly dubbed "Super".
This is speculating so don't rely on it too much... :roll:
enzo
Post by enzo »
but, why waste time searching this specific coil-pack if you can use other ones?
This info can also be interesting while hunting for a complete engine. :wink:
enzo
Post by enzo »
ups...wrong pic of the engine...
here is a pic of the alfa parts cd
(coil pack with cover on the 164)
ryn079
Coil Packs on 1962cc Twinspark
Post by ryn079 »
Hello, is it possible to install the coil packs of a 155 Twinspark on my 164 T.S with distributors? If yes, from where am I to get the signal to power up the coils?
Ryan
tomp
bundled spark leads...
Post by tomp »
Anyone have thoughts on bundling of ignition wires as shown in the parts cd above? Ive havent seen the 164 coil pack setup myself but the part diagram shows the ignition wires bundled tightly together. Ive always read this is a no-no for good ignition performance. Cross fire may not be an issue in this case but its seems likely spark energy is being bleed off. I guess a COP setup would not have this exposure since all the leads are low tension.
The std setup on the 75 TS has them all tightly squeezed together in a plastic clip. No problems.
Post by la_strega_nera »
junglejustice wrote:I doubt that the Australians have them readily available from their friendly "local Alfa Romeo dealer" either...
If its the same as the coil pack on a 3.0l 164, then no, they're not hard to get hold of.....
junglejustice
The picture above of a 12v car with red cam covers clearly shows a single coil - not a coil-pack - that is all we had here in the US other than coil-on-plug 6 ICPs on our 24 valve 164 cars 1994-1995...
We can't get the 6-pack coil-pack type from 155s here...
I can't tell what type of 164 that is in the other picture - single-coil not vissible - maybe it is there and just hidden from view at the angle picture was taken (behind the rad. - maybe that is a picture of a European car that does have a coil-pack hidden underneath the square black plastic cover up on the back of the front head...
Either way - we did not have 6-pack coils here in the US such as on the 155 on our Alfas...
I stand by what I said - rare (for us then if you must...) The South Africans also "cry" for them, but this does not change the price any - it is just a supply issue.
Back to my original question - anybody use them? Anybody need them?
