Plenum & Runners
Plenum and runners are finished.
David
David
- Plenum & Runners
- DSC04173.JPG (19.33 KiB) Viewed 12957 times
164 TDC
I'm ready for a test engine assembly to check piston to valve clearance.
On the 164 can someone tell me what is used to check TDC. The 164 front pulley has a mark on it that lines up roughly near the crank sensor.
David
David
Update
Just an update on the project so far. The engine is just about completed. Higher flow injectors are on their way and the MS components for converting the V2.2 board for spark are being ordered.
A few issues to overcome when using the 3.0L crank pulley and water pump as the pulley sizes and alignment are different than bolting on all the 2.5L stuff as I did last time.
The alternator is now driving off the pulley that the 164 power steering pump originally used. I am modifying the 2.5L AC compressor mount and then the second belt will drive the water pump and AC compressor. Will also be replacing the old Yorke compressor with a smaller rotary unit off a 75. This should just clear the oil filter.
David
David
- Silicone runner joiners
- DSC04187.JPG (79.98 KiB) Viewed 12765 times
- DSC04195.JPG (44.21 KiB) Viewed 12765 times
Guy's,
i am trying to find some new engine mounts,both of the one's in the car when i pulled out the 2.5 were cactus,i didnt think much about it at the time as i assumed they would be rather easy thing to get hold of,but after trying several shops around syd today have found them to be rather hard to get new
,so anyone know of any anywhere,i found some on ebay but they are the whole setup (alloy bracket and rubber)i only need new rubber. and i thought $220 a side was a bit rich !
cheers all
cheers all
86 GTV6 GP
90 164 (ENGINE DONOR)GONE !!!
2013 Mito for the Wifey.
86 GTV6 GP
- ALFA GTV6 GP
Fletch
Did you try Turin imports ?TURIN IMPORTS | 81 Drayton Street, Bowden SA 5007 | Tollfree: 1800 888 225 | Ph: 08 8346 0000
John
John
Alfa GTV6 3.0 (Silver)
Alfa GTV6 GP 3.0 (Red)
Alfa GTV6 GP (Concourse)
