today i striped down 3 gearboxesMats wrote:Not sure about this but the diameters of the shafts between the Alfetta and 75 boxes are not the same, neither is the splines for the fifth/reverse gear assembly.
some update ... bad news Mats is right
clutch shaft reverse-fifth gear have completely differnet splines ... may be 3-4 is different too
here some pics .. note spacer between 4-5 gear that wears out and cause diff whine with 90-100 km/h on 4-5 gear ...
original tickness is 2mm .. on my TS box was 0.5mm
this clearence cause pignon shaft to float for-backward
- HPIM0883.JPG (211.08 KiB) Viewed 3344 times
- HPIM0886.JPG (215.38 KiB) Viewed 3345 times
- HPIM0887.JPG (204.68 KiB) Viewed 3345 times
- HPIM0888.JPG (196.15 KiB) Viewed 3344 times
- HPIM0890.JPG (201.85 KiB) Viewed 3345 times
