matfo
Post by matfo »
Here I'm testing the manifolds and I think it looks really good :lol:
manifold
manifold
DSC00093 (Small).JPG (68.01 KiB) Viewed 3957 times
Mats Forssén
75 TS
159 1750Tbi SW
http://www.matforacing.se
matfo
Post by matfo »
Testing in the car
manifold test 2
manifold test 2
DSC00122 (Small).JPG (70.63 KiB) Viewed 3954 times
Mats Forssén
75 TS
159 1750Tbi SW
matfo
Post by matfo »
from below
from below
from below
DSC00128 (Small).JPG (51.69 KiB) Viewed 3953 times
Mats Forssén
75 TS
159 1750Tbi SW
ar4me
Post by ar4me »
Is that one of the bolts for the lower control arm that has been cut flushed with the nut? Hope you never need to adjust front camber (to more negative)... Guess you can go visit a wrecking yard for a "new" should it be necessary. I suspect you prefer the extra clearance for the downpipe.
matfo
Post by matfo »
ar4me wrote:Is that one of the bolts for the lower control arm that has been cut flushed with the nut? Hope you never need to adjust front camber (to more negative)... Guess you can go visit a wrecking yard for a "new" should it be necessary. I suspect you prefer the extra clearance for the downpipe.
Yes, thats right.
However it has been looking that way all the time I have had the car. Haven't actually thought about the lack of possibility to adjust to more camber so thanks for the "heads up" on that.
Mats Forssén
75 TS
159 1750Tbi SW
