Mats, rather than just kill the idea can you (or anyone) explain how they are "matched"? I presume the teeth match up and engage correctly.
Is it a matter of diameter and length?
Jef
www.motozane.com
www.motozane.com
as far as i know NO car company or gear company has EVER made a set of ring and pinion gears that you can swap a pinnion from say 410 to a ring gear of a 355...they would never line up its a simple matter of size and gear mesh......sure the gear pitch is not an issue its the simple fact that as 1 gear gets bigger the other gear must get smaller
that said i dont see why you couldnt swap a "early" 410pinion (say in the case of the old gear drive for a fetta or gtv6) into a LSD plat or TS box with the plat/ts 410 ring gear........not wise but if someone set the gear mesh and tolerances it would hold up it just would likely whine
The early pinion and late pinion are very obviously not compatible when you have them side by side.sh0rtlife wrote:as far as i know NO car company or gear company has EVER made a set of ring and pinion gears that you can swap a pinnion from say 410 to a ring gear of a 355...they would never line up its a simple matter of size and gear mesh......sure the gear pitch is not an issue its the simple fact that as 1 gear gets bigger the other gear must get smaller
On the swapping pinion/ringgears issue I can't explain it without a long technically heavy post about complex stuff. It's easier to make a comparison.
Why doesn't anybody ever try to swap a 3.0 crank into a Nord to get more power?
I did. It works really well. You just have to move the block, pistons etc etc with it and remove all of the extranious nord bits.Why doesn't anybody ever try to swap a 3.0 crank into a Nord to get more power?
Seriously, mismatching between ring and pinion sets, even of the same type (say 75 TS to 75 TS), is not easy - they need to be lapped together for a decent result. Once you step ouside this to different ratios, it just doesn't work.
