hum...of course but: the ball bearing on rear side of the flange is X contact one (angular&2inner pieces), so this should not.Mats wrote:I find that incredibly hard to believe, there would be severe problems when reversing drive on the pinion if you don't have anything to hold it in that direction.
however... with this fitting...the rear bearing should last no long as the models whith 4 ball bearing on middle flange.
should..should...
often...( very often (statistic wiew) ) something else will fail before.
however &/or/??? often :
when roller fitting...make us think that the second shaft ball bearing with shoulder, because of him avaibility =0 make people (me) afraid for long time service with him reused..
Did someone get a source for ?
