Greg,
You're correct. Plus, my car's undercarriage is relatively dry and has no rust, caked on gunk or other nasty stuff. The center exhaust comes off in 5 minutes (all flanged) :)
Exactly. When you get a car that has exhaust flanges that are rusted together, and bolts that have more rust than metal, this can turn into a pretty ugly job.
I am not saying that's the case with the car in question here. I am saying that sometimes it's quite possible and reasonable for a clutch job to take a thousand dollars in labor.
Of course I strongly suggest getting a disk from Andy and following the procedure on my site, this saves a lot of money and results in a clutch that's as good as new.
badger77
Post by badger77 »
The car in question was never winter driven. It has no rust, the body is in excellent condition. Well the paint faided a bit and has couple of chips. I think the overal price is a bit high still. The same mechanic tried to charge me for a water pump $200. I was able to find one new, for $77. Big difference... Actually I did not find place that would sell it for more than $100. I say it is Monopoly, there is no one else in my city that specializes in these cars...
thank you a lot ... for all the comments...
It very well might be that he is charging too much. If the car is dry underneath and nothing is stuck or damaged, I would think it would be a 5 hour job tops.
badger77
Post by badger77 »
Thank you, I am not sure what I woud do without this forum. Ok, I found a place here in Ottawa that maybe able to rebuild the clutch, for 360$. I have a good mechanic that will install it for another 200 bucks. This saves me 1500 dolars if it works out...
Thank you again, for all the ideas.
jjeffries
Post by jjeffries »
what is the difference in terms of time/effort to replace the clutch between old style linkage and newer style (isostatic?) linkage? The latter is more difficult, correct?
No material difference.
I remember a certain crosspin that is a b*tch to remove in the newer linkage. Other then that it should be the same.
