This is from the braking zone going into the first corner...
Tight enough for you?
Now this was a close call, the guy in the 75 started braking about 50 meters earlier then my brake marker and I was slightly suprised ( ;) ), had to slam the brakes and locked the tires. When I started braking I was at about 7000 Rpm in third (TS box), this distance is "quite" close at those speeds. I probably looked like this: :shock:
Turbo GTV with flaming sidepipe, you just gotta love it... :D
