Duk
Re: V6 12v Individual Throttle Body
Post by Duk »
How's your 3D printing game, Z-man?
Design and print a decent plenum chamber in nylon. Just make sure there aren't any large flat surfaces.
It might look a bit like a dogs breakfast, but you don't look at the plenum when you're driving the car.
That OKTech plenum is pure art.. 8)
I think any of his setups, either the really nice 2 piece RWD plenum or ITB is no less than $3K. Makes the AHM/Jenvey setup look like a bargain.
KevinR
Post by KevinR »
The Jenvey’s are really designed for the front wheel drive Alfas to fit under the bonnet hence they are sooo short. Ideally on the 24v when placed in the transaxle should have a longer runners with throttle bodies each side above the cam covers .
This is a current project leading on from the throttle body set up which we have just done on the 3.0 Carb heads . The new throttle body set up I will a mere spectator this time :)
Alfaaa1
Post by Alfaaa1 »
Hi to all, Mine are Jenvey throttle bodies on my 3.2 24v and the engine runs like a dream.
Alfaaa1
Post by Alfaaa1 »
If you go to Instagram and type in boost_tech_performance, and click on the photo you can see the film clip of my engine being dyno tested.
Screenshot 2026-01-19 at 10.17.16 am.png (76.18 KiB) Viewed 5870 times
