cchan
82 GTV6 3.0L 24V Restoration/Modification
Post by cchan »
Hi Michael,
Here is the map from my conversion. Specs are in the introduction section. We tuned my Alfa for the higher HP but still not full HP per Phil's advice. Alfa dyno tune print out showes 211 hp at wheels but Paul (dyno tuner) said his machine spikes up so 204 hp at wheels is probaby a more conservative reading.
Final Map.dfi
(7.77 KiB) Downloaded 600 times
Michael
Re: Gotech Maps upload/download location
Post by Michael »
Gotech MFI Pro Chipset v5
24 Valve V6 3.0, GTA intake cams.
Stock 164 LS Fuel Injectors.
Mixed mode (MAP/TPS) - TPS is from Porsche 944 Turbo.
218 RW HP @ 6300 rpms
185 ft-lbs Torque (fairly flat curve from 4600 rpms)
CC1_dyno.dfi
(7.73 KiB) Downloaded 605 times
Michael
1981 GTV6
