Define "seriously worked over".
I use the old 2.0 parts. The drive shafts weigh 12.8 kg instead of V6 parts with 17.0 kg. Nothing broke yet.
I even have the small front bearings which now needs replacement (after about 15 years). They last much longer than the rear bearings which are the same in all models.
BTW, I just checked the data logger from yesterday's race. 1.284 g left hand turns and 1.299 right handers. This on normal street tires (no semi slick).
Impressive Micke..that wants to be done...!Micke wrote:Define "seriously worked over".
yes i agree that is seriously impressive micke. what is your data under braking then just for my curiosity? and what road tyres are you running? basically even if you were running standard-ish brakes your braking g forces should also be as impressive even with the use of road tyres or am i wrong in assuming this.
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
sorry correction..by simply being able to pull those sort of g forces around corners on standard road tyres shows your existing setup is on the mark in regards to spring rates and the like etc etc. not to discount that they must be some good bloody road tyres which as we all know tyres are the limiting factor to a cars brakes no matter how big or powerful the brake system may be. if the wheel locks up then you have reached the limitations of the tyre basically, which leads me back to my quaestion of the amount of braking gs u pulled which will in turn give me a rough sort of indication to how good ur tyres r. sorry if a little off topic just in the midst of searching for some good road tyres atm so what a chance.
patzo_3l
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
Or you have bad shocks or too much camber or bind in the suspension and so on.patzo_3l wrote:...not to discount that they must be some good bloody road tyres which as we all know tyres are the limiting factor to a cars brakes no matter how big or powerful the brake system may be. if the wheel locks up then you have reached the limitations of the tyre basically...
I checked the sampling rate. 100 Hz.
While looking I found the max value is over 1.3 g. So, there's some filtering which lowered the max value.
The lateral acceleration was above 1.25 g for 0.6 s or about 15 m.
Braking figures were not that impressive. I found the sensor was slightly tilted and the deceleration even corrected is just 1.05 g. 2 reasons for this. Brakes were slightly front biased (changed from last time I drove the car due to mods. This I corrected during the race) and BAD driving. Next time I'll brake better. My only excuse is that I didn't drive the car since 2001.
Tires are Hankook RS-2 in 225/50R16. They will improve as they still had 100% tread depth.
Micke,
17 kg vs. 12.8kg for the driveshaft? Wow, 5Kg spinning at 6K rpm. Sounds like a good place to get better acceleration using stock parts.
Also the from what I've read RS-2 is a very good street tire. Possibly the best for the money, and still up there with the best street tires. Good for practice sessions prior to the end of the day's qualifying and actual race.
Zamani,
Micke wrote:
My US milano V6 driveshaft is 27 lbs - just weighed it.
Micke wrote:
I think he is talking about the half-shafts. In that case, not necessarily spinning at engine RPM, though still 5 kg less spinning.Barryman: When you put the DeDions on the scale they might have included the driveshafts?
From the context it was clear.
10 kg, that is about 5 lbs less than my milano v6 prop/drive shaft
Do you have the shorter one, or did you do something custom?
mats wrote: Or you have bad shocks or too much camber or bind in the suspension and so on
yes mats you are also correct but for the simple reason i didnt wana sit here and make a list of possible causes that i couldve filled a page up with lol i didnt bother moentioning. so micke from what i have read then are you saying the sensor was not mounted incorrectly then and the figures were not 100 percent accutrate. doesnt matter whatever it is now but i would be curios if just again for my own purposes have a copy of ur data log or stats if u have them lol i love fiddling with this stuff so indulge me pls
cheers
cheers
patzo_3l
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
I have a couple of clutch assemblies I can weigh, one is standard, the other is a custom lightweight special
- Flywheel with cover
- KIF_0853.JPG (203.77 KiB) Viewed 10718 times
- Lightened flywheel
- KIF_0851.JPG (252.28 KiB) Viewed 10719 times
- Standard flywheel
- KIF_0848.JPG (220.65 KiB) Viewed 10718 times
