Fris75turbo
Post by Fris75turbo »
JimGreek wrote:...well made head (std valve sizes) about 8.5:1 CR...
Hi Jim!
Tell me please, do you plan to change pistons or reduce combustion chamber volume to get that CR? Or both? :wink:
Regard!
I have a new std piston/liner set, the higher CR will come from milling the head.
Fris75turbo
Thanks Jim for the info! 8)
Right now, i have V.Reintz head gasket, and works very well, but...
If i increse CR and boost preasure (to maximum 1,2bar), do i need to think about some custom made cooper head gasket or something similar? :?
Regard!
No way. Just ditch the std engine management. :)
It may be a good idea to go for a Spesso performance gasket, although I don't know how good or bad the std gasket is with higher pressure. I don't have much info for turbos.
I believe std management works ok for up to 1bar as I drove the pi$$ out of the 1.8T in the track for more than a half hour last month with 35-38*C ambient...this is a 'worst case' test for me. The engine is stock except for a special chip for 0.9-1bar and a little higher fuel pressure. Ran very well, almost keeping up with the much heavier 3liter; 1sec slower due to very worn semi-slicks compared to much better tires of the 3liter. Of course, better management, mapping and a modern snail would make the thing fly but it all depends on what you are willing to spend and what you are really after.
Fris75turbo
1sec? :)
Not bad! 8)
I can't imagine the temperature around the snail after a half hour of cooking on the track... :wink:
I honestly believe in good prepared Turbo Nord. My humbly opinion is: if you spend same money on 1.8 turbo and V6, gain will be bigger on the Turbo! :wink:
For example: How much money and work is need for +35hp on V6? On turbo is something around 350euro and half hour of work... right?
Chip, hip, hura!!! :lol:
There really is no comparison between the 3liter and 1.8Turbo! 250hp for the V6 requires substantial amounts of money; for a turbo, this number can only mean a chip and a better exhaust system! Now if you start porting, cams, ECU + intercooler changes, you're looking at over 350 reliable hp and a LOT of torque!
Fris75turbo
14 days of holidays are over... :cry:
Hi guys, hi Jim K! :D
I respect V6 very much, but i love my 1.8 Turbo much more! :wink:
Anyway... i have one question... again :lol:
How much hp engine lose with low octane fuel? Right now, "the best" fuel on the market here is 92oct! :( Turbo "eat" 98oct, right...
Is this reason for maximum pressure of 0,50bar or i have a problem with something alse?
When i set ignition timing on 10" i have red light ON, knocking, and "safety" 0,30bar-pressure-driving-pleasure :evil: .
Right now, ignition is on 8", knock-switch on Control Panel stay in OFF (like Mats say once...), everything work fine but, like i said, with max 0,50bar... :?
BTW, here's something which might interest a Turbo builder.
I know someone who has an original turbodelta piston and liner set. He doesn't need it (but knows it's value). If anybody's interested I can forward the info.
Turbodelta piston and sleeves set.jpg (82.63 KiB) Viewed 9709 times
Fris75turbo
If someone know, tell me please:
In which car goes (factory) Marelli BK3A coli?
Maybe i can find some second hand... i hope so. :?
Second hand is your best bet. A great many Fiat and Autobianchi owners used these coils in their cars.
Fris75turbo
I plan these days (finally) to put 10548 cam on my 1.8T.
One thing was always mad me about standard intake cam:
After 5000rpm engine start to loose breath. Bunch of useless rpm... :(
Now, my wish is keep a low rpm power and put some new life after 5000rpm.
My question is: How to set intake cam? Lobe center timing around 105*?
Help me people! :wink:
Regards
Fris75turbo wrote:I plan these days (finally) to put 10548 cam on my 1.8T.
Regards
It's not the cam, it's the comperssor on the turbo that is completely useless. I switched my turbo to a Mitsubishi that has a very small turbine and a larger compressor, the car was very nice all the way to the red line. Everything else was unchanged.
A new GT28 would be even better- flow and spool wise. The flange isnt heaps different either, but there's no point going to any length other than exhaust and chips without reprogrammable management!
