Evert
Re: 3.0 V6 12V Twin Turbo
Post by Evert »
Need som injectors for the project.
Bosch: Anything between
From 328cc to 394cc.
The more the better.
Anyone knows an adress, I preffer England.
Evert
Post by Evert »
Evert wrote:Need som injectors for the project.
Or a Bosch code table would be very helpfull..
scott.venables
Post by scott.venables »
Volvo R injectors (Green), 365cc. Available cheap everywhere. :)
Evert
Post by Evert »
Giuliettaevo2 wrote:http://www.marktplaats.nl :wink:
You mean this one??
http://link.marktplaats.nl/238440687
Looks a bit to small.
Code is: 0 280 155 733
http://www.bosch-motorsport.de/pdf/comp ... s/EV_6.pdf
261,2 g/min
Code origional is:
Code is: 0 280 155 105
Evert
Post by Evert »
Mats wrote:Volvo R injectors (Green), 365cc. Available cheap everywhere. :)
Do you mean this one:
B 280 431 129
of the same sheet:
I have no idea, sold the ones I had and replaced them with Siemens 620cc units. 8)
Edit, these are the ones.
Bosch nr: 0280 155 968
420-427cc @3 bar
465cc@3,8 bar
Green Volvo R injectors
http://link.marktplaats.nl/240113564
Just search a bit and find things like these... :wink:
Evert
Post by Evert »
Giuliettaevo2 wrote:http://link.marktplaats.nl/240113564
Are you sure they fitt?
I can make a good deal with the seller.
What the heck, I just bought them. Hopefully one step closer.
rz
Post by rz »
there are only 4 of them??
is that right 12 ohm?
Evert
Post by Evert »
rz wrote:there are only 4 of them??
4 is more than enough.
I'll drill extra holes for the other 2 cylinders and use two of the old injectors.
Two of the old injectors should equalize with one of the new injectors for the fuel flow.
Just joking, bought 6 of those red guys.
Thanks Giuliettaevo2 and Mats for the advice!
Evert
Post by Evert »
Hello Guys,
I got a further question.
The six red Bosch Volvo 0280150431 injectors look very alike the green ones.
So without the flexible connections as in the standard Alfa V6 0280150105 injectors.
Can I make the flexible connections also on these injectors or should I customize two Volvo injectorrails for them?
Evert wrote:Hello Guys,
Just use parts from a 164 engine to make it accept O-ring injectors. Simple and much better then the barbed ones.
Evert
Post by Evert »
Thanks Mats,
But I can get my hands on the 164 12V injectors and the 24V injectors.
There seems to be a difference.
