Flex joint, etc.
So, if we were to use the stiffening plate on the 3 driveshaft yoke bolts, what template would we use for the holes? When the metal band is around the flex joint, the bolts go through fairly straight. When you release the band, they flare outward slightly. Should we strive to prevent this outward flaring, or not? Or does it not matter?
-Al
-Al
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
- Maurizio
I think it doesn't matter. I would use the pattern with the metal strap around the joint. Makes assembly easy.
After everything is tight bolted you can release the strap.
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
- junglejustice
